Running Low Anti-freeze in Coolant?
Rustynuts
Tampa
With my overheat problems, a friend mentioned I could maybe run the system lean on antifreeze. What kind of mix can you use lower than 50-50 to keep the anti-corrosion properties?
I live in Tampa, so I don't really need full anti-FREEZE protection! Can you get other additives like wetting agents to use with water instead of normal anti-freeze?
20% and you can use some of the surface tension reducer stuff too more effectively at that concentration.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
We go 50-50 here in Quebec , but we really got HARSH winters.
more then that will damage the alloys-gaskets-corrosion.
More theres coolant in the water , more itll prevent boiling-overheating.
But sometimes you might have another issue (EX:thermostat) that might not even connected to the coolant itself.
