Pulled my plugs, they are pretty grey. I'll clean my MAF tonight (no-residue brake cleaner ok?). Is there anything better to clean it with?
I'll also check for vacuum leaks. If I attach a vacuum gauge to the intake manifiold, what kind of numbers should I see at idle?
I seem to have very very small leaks on the intake manifold rubber seals. There are slightly dirty/oily film spots where the rubber joints are. These have built up over the course of 50K miles. I thought the intake was under negative pressure. Does it ever get slightly positively pressurized?
I also have dirty/oily vent spots around the valve cover bolt seals.
Could this be causing the lean condition? Is there anything besides a vacuum leak or out of whack MAF that causes this?
Thanks,
Thanks,
