Larry Bialecki
Forum, thanks for info on water pump leaking when cold. Replacing the pump took
only 3 hours and did not require I remove/replace the timing belt. The pump did cost
$165 at Pet Boys. The only problem now is that I seam to be running hotter. Before I
ran with the needle between the M and A. Now it starts there and then slowly moves
up to between the O and R. It was a hot day (106) but I seam to remember not going
that high on a hot day. Does anyone know the temperature values for the gauge?
What temperature is the engine at when the needle is pointing to a specific letter?
On a second problem: My ATX is having some problem shifting to 3rd, both in the upward
direction but primarily in the downward direction. The problem appears more when the
vehicle is hot. The transmission has about 162K on it with no slipping as far as I can tell.
The last fluid change shows no parts or ware indication in the pan. What is a "Shift Kit"?
Could my shifting solenoids be sticking? I am getting error code 641 from the computer.
Would a leaking water pump have any affect on shifting? Problem with CPS?
Any suggestions?
Any suggestions?
