Rough idleing
JVANBUREN
holly, mi
I am having a problem when you are rolling to a stop at about 30mph my car wants to idle back and forth from 500rpm to 1100 and it will keep doing it, and just recently on my way back from a trip I had the cruise set at 75 and it seemed like it was free reving from 2500rpm to 3000 and it would so this every minute or so. My car also seems to be running preety rich. fuel pressure is good.
1997 Taurus SHO
wuzzzer
MN Moderator
St Cloud, Minnesota
I'm going to assume that when you were driving on the highway you had the A/C or the fan on, correct? This is normal operation that happens when the A/C clutch engages/disengages. It causes the RPMs to fluctuate a little bit.
For the other thing mentioned, I guess I never looked at my tachometer much as I was slowing down, but it could very well be the car just downshifting into a lower gear?
Mr. SHO
Philadelphia
Sure sounds like the TPS to me. Check the TPS wiring. Sometimes cleaning it up helps. Other times, the TPS itself, or the related wiring needs to be replaced. The TPS is uber-cheap and available everywhere (standard Ford part).
It could also be the IAC, but that's less likely and more expensive. Swap the TPS first.
JVANBUREN
holly, mi
THANKS!!!!!!!!!!!! it was the tps. I was stumped because it was not throwing any codes.
SHOMEX
Taylorsville, Utah
TPS = Throttle Position Sensor. You can clean the connection to the TPS and see if that fixes the problem or replace the TPS.
