Rookie Tire Question
Brian685
Philadelphia
I just bought a set of 16" slicers for my '89 (has the stock tire size and basketweaves on it). I was wondering if the 225/60/16's on the slicers will be alright.
The tires on the 15" are 215/65/15. I know there's a difference but in your opinion, is it that bad?
- Brian
noSHO
ohio is for hustlers
Brian- I'm running 225/55/16 on my slicers, and personally I like the look. The sidewall height is just a little shorter and makes the tire look better, but not so much that you get really big wheel gap that looks lame. However, 225/60/16 should work fine if that is what you want. Let's see some pics when you get the new slicers on the car.
-Dave
Green 92 77k coneless, fishtanks, K&N panel filter, SHOnut reinforced motor mounts, SFCs, Perf. Plus Y-pipe, Summitracing Turbo Mufflers
6710073 c8c4 00800037
Brian,
The 225/55-16 size is much closer to the stock 215/60-16 size than the larger 225/60-16. The 225/60-16 can cause some fender liner rubbing in the front and plastic trim interference on the left rear.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
Brian685
Philadelphia
Hmmm I installed them and checked out the whole turning radius looking for contact. None while standing still. I realize there are better tires for the job, these just came with the wheels. At least I know what to replace the 60's with.
The car looks great! I washed and waxed her and then mounted the new wheels. We'll see how it goes. Thanks for the help guys. I really appreciate it.
- Brian
Currant Red '89
98k miles Stock
Brian685
Philadelphia
By the way, the centercaps currently won't snap on. I need some open ended lug nuts. I guess I can't use the anti-theft one (whatever it's known-as) ? Or is there a way to get a shorter version. Pep boys had nothing.
- Brian
Currant Red '89
98k miles Stock
olympic
Saskatchewan, Canada
You can get open ended lug nuts with anti-theft. I've seen them in Canadian Tire but since your in the USA I guess that doesn't help much...lol.
