Minus the extra metal idea, I successfully welded that badboy. not only tack welding the bracket back together, I welded 360 degrees around the rod on each side of the bracket. Fords little weakness has now become reinforced, so I won't be needing to spend any money nor having to put cash aside for a rod shifter fund as Shoman594 does.
SHO--Ripper, I appreciate your sweet offer, I'm shure Rootbeer88 will benifit greater from your rodshift package.
Rootbeer88, if you buy it, you will still need to by a resonator exhaust midsection off a 91 or newer SHO. There is an extra "kink" in the pipe that allows the extra room for the rodshift vs. your old cable shift.
Thankx to all for your replies, but I give most credit to CrazyTaurusSHO. I dug up an old string of his, and he too had success w/ a simple weld.
