Okay so heres the deal I just recently under took an A/c conversion on my 92 mtx sho. After replacing all the lines, condenser, and dryer my A/c finally should a glimmer of hope and was blowing cold air. The low side pressures are right but unfortuantly the high side pressures run about 400psi to about 450. When I give the throttle enough gas to maintain about 1800 rpm the high side pressure jumps off the gauge to over 500 psi. So the car runs with a/c but if I am in alot of stop and go traffic the car tends to over heat. After doing some research about A/c's in general I made a few interesting discoveries I thought I would share with the rest of you. I did a search on this forum about a week ago for "high pressure sensor", but to no avail I only found certain threads where people say they have found the low pressure sensor but for the life of them they can not find the high side sensor, plz help!!! Well turns out that R-12 systems where designed without them because of different heat exchange ratio's. This is why the high pressure side of my A/c runs such a high pressure. Also this means that the A/c compressor is running over time and rarely turns off. In addition because the gas is expanding and condesing alot faster then it should be the radiator fan is having trouble cooling both the engine and the condenser. Heres my question Cold air sells a high pressure sensor for the taurus sho. Has anyone ever tryed to install this before and if so what did you use, Where did you make your electrical connections, or even if I am just blowing smoke out my ass and this wont even work. MAybe theres something else I over looked. I appreiciate any input thanks!!!
Stephen Prochilo
Stephen Prochilo
