Zap
I've done a bit of searching / reading again on the RKE system in the Gen II. The '94 has had issues with this for some time, and I'd love to resolve it if possible. Basically, the range is nonexistent. I've tried using another remote, and the problem isn't any better, so I suspect either the antenna is messed up or the module has a problem.
Can anyone tell me where the antenna runs? Does it just go along the inside of the trunk or elsewhere? It might be possible that it fell off if it is taped in place, and a curled up antenna isn't so great, so that could explain the bad range. It may also have a break in it or at the connector.
Otherwise, has anyone had poor range resolved by replacing the RKE module?
Thanks!
Thanks!
