reverse grind
Infantryarmy09
Seoul, South Korea/ WI
All of the sho's i have ever owned it will grind into reverse most of the time.
Is that a clutch issue? Or is that just something they do?
Again so i make it clear though it doesnt happen everytime just most of the time.
MADDOG11
Houston, Tx. Denver, home
Try going into 2nd, 4th then into reverse. That usually stops any grinding. I believe it's because that reverse is not a sycro'ed gear!?! Correct trans people?
dodgebusta
Online/Offline
Hudson, WI
that is correct somebody posted a pic of what came stock on the shifter, shift into I believe 4th then over to rev.
