Reusing the shims
Goulash
Urbana, OH
I read on SHONut that you can just as easily flip the shim over and use the marked side, provided that you remark the number on the formerly worn side? Are there any opinions or experiences with this? Thanks...
- Justin
yamahaSHO
E85 whore
Arkansas
You can reuse shims just fine... You can use any side provided they are not too worn or damaged.
Goulash
Urbana, OH
Hey dude
You can probably guess that I'm deep in the valve lash job...that description on the SHOPP is wickedly helpful. I need to find a few shims for those which are out of spec, but I'm just going to flip the others. Then I can actually DRIVE the *******. :)
Dr. Tweak
Mad Scientist
Northern Vermont
DOH!
It's ******* Focker, get it right.
I have a shim kit, but I won't be getting it back for a little while. I've got some around though, which ones do you need?
yamahaSHO
E85 whore
Arkansas
I'm always up late... Waiting for Chris to drive up here so I can get my TwEECer back... I finally have some real time to tune. :D
