Reusing Head Bolts
DHMag
Free At Last
InCahoots, Texas
ive read only a handful of posts about reusing them. just making sure everyones still in agreement about it, namely Fred. or, could any other bolts be used in leiu ? like grade 8....
TIA
twr
whoohoo
half-way there, I think.
You can reuse the head bolts on the V6 motors. Since the V8 is an all aluminum block, it uses torque to yield bolts (protects from stripping out the block) I would not use anything but the correct bolts for attaching a cylinder head to a block.
DHMag
Free At Last
InCahoots, Texas
thanks for the speedy reply Terry. it sucks not having the internet at my disposal any more. shoulda paid the phone bill instead of buying SHO parts.
rangerj
Brunswick, Ohio
As a rule of thumb the head bolts can be re-used about 2 to 3 times. However, you should always check the threads with a straight edge. All of the threads should be touching the straight edge evenly. If not, the bolt is stretched or warped.
Check the bolt in 4 places 90 degrees from each other. This will tell you if the bolt is straight and whether it is stretched, or not. rangerj
revhardSHO
Seattle, WA
The 3.8L (a.k.a. POS, headgasket blower, crap, etc) 232 ford V6 uses torque to yield head bolts in a cast iron block...I was under the impression that the "stretch" design was used to compensate for head gasket compression over time; so as they would not have to be re-torqued later later on down the road (in other words, they should last the life of the engine). TTY head bolts should not be re-used, and this is definitly not an area to "cut corners" in.
The Yamaha V6 head bolts are not Torque to Yield design; and as stated they can be re-used per proper bolt inspection.
