SHOTerror
I have decided that soon I will be putting my '90 SHO on jack stands and pretty much restoring it. So far I have compiled the list below of what I am going to replace to give this SHO the power and reliability it deserves!
Also: I have decided to search out the best compenents, no rebuilds etc I want all new stuff nothing but the best!
Accessories:
A/C Compressor w/ clutch
Water Pump
Alternator
Sensors
CPS Sensor
MAF Sensor
TP Sensor
Thermostat
Belts
Timing Belt
Accessory Belts
Ignition
Spark Plugs (Motorcraft Platinums of course)
Wires
Coil
Transmission
Rod Shifter Conversion
Syncromesh Fluid
Friction Modifier
Cooling System
All Hoses
Water Pump (Repeat)
Thermostat (Repeat)
Miscellaneous
Fuel Filter
All Seals
Rod Bearings
Flush All Fluids
Valve Shimming
Electronics/Interior
'91 SHO Computer (Good idea?)
LPM
Alpine Head Unit
Dual 10" Sub Box in trunk
4 3-Way Speakers
4 Channel 1000 Watt amp
2 Channel 1000 Watt amp (run in mono bridge mode)
New Carpet (1200 quality)
Exhaust
SS Y-Pipe
Bosch o2's
Sumit Turbo Mufflers
Bent Resonator (Rod Conversion)
Chrome Tips (No WOOOoooo Woooo; Vrooom vroom
Intake
Pro-M 80mm MAF
Cold Air Snorkle
Suspension
Intrax or Eibach Springs (Let me know)
Koni or Tokiko (Again, let me know)
Brakes
New Pads
New Rotors
Please let me know what you think of my list and what you think I should add/remove. I have a passion for these cars and have become more and more mechanicaly inclined since I purchased my '90 and I am very anxious to tear her down and build her up to be reliable, fast, comfortable, and a true classic. Again, I am going to research all the best providors of the above and get all new components. I think this is the best way and would like to know if you agree with buying all new from quality providors over rebuilt/refurbs.
<small>[ April 24, 2003, 04:19 PM: Message edited by: SHOTerror ]</small>
Accessories:
Water Pump
Alternator
Sensors
CPS Sensor
MAF Sensor
TP Sensor
Thermostat
Belts
Timing Belt
Accessory Belts
Ignition
Wires
Coil
Transmission
Syncromesh Fluid
Friction Modifier
Cooling System
All Hoses
Water Pump (Repeat)
Thermostat (Repeat)
Miscellaneous
Fuel Filter
All Seals
Rod Bearings
Flush All Fluids
Valve Shimming
LPM
Alpine Head Unit
4 3-Way Speakers
Exhaust
SS Y-Pipe
Bosch o2's
Intake
Pro-M 80mm MAF
Cold Air Snorkle
Suspension
Brakes
New Pads
New Rotors
