Replacing power steering hose, motor mounts, and cv's anything else while I'm at it?
Terrorizer
SHO or ****
Hi all. I recently replaced my rack and pinion on my 1990 SHO. Unfortunately the power steering pressure line is leaking as well. While I'm at it my motor mounts are bad and so are my CV axles so I'm replacing those as well. Obviously you guys don't know what else may be needing replacement on my car, but based of replacing those items, is there anything else I should be replacing while I am at it? Figured I'd ask now before I get it all torn apart. Any input would be appreciated.
check the inner tie rods for slop and, if you have a welder, hit the subframe where the strut tension rod comes through. I think there is an insert at the hole in the subframe where it comes through that comes loose or breaks/rusts away. mysterious clunking under the front...http://www.shoforum.com/showthread.php?t=94480
ribeye2065
