Replacing Headlights
0V3RC10CK3D
Washington
I've searched high and low but can not find a guide for how you replace the headlight casings, I bought some brand new sable lights and I'm looking to get them installed without breaking anything. LOL.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Just pull up on the clips. I found grabbing from the side helps. The top of the tabs do tend to brake off.
0V3RC10CK3D
Washington
It looks like it's mounted into this black part behind it, which is screwed into the frame...do i take out the black piece with it? or no?
SHOwener1986
no you dont, there should be clips right behind the black headlight bezel. Just pull the clips up and the headlight comes out. I used a right angle set of needle nose and it worked great w/o breaking anything.
0V3RC10CK3D
Washington
I know its a lot to ask but does anyone have a picture floating around of what I move? I hear its easy to break something and i don't want to mess it up.
LOUDSHO92
Sponsoring Vendor
Yes those clips, and the black part stays.
Just pull up. To help you can open them up a little and they will come out easier.
93rev2sev
Hockeytown
Bent a coat hanger at the ends. Put the ends in the holes. Pull up while spreading the little holes.
