***New Minor Developments***
Just came from grounding the fuel pump test pin on the EEC to the negative battery terminal and the pump still didn't initiate, assuming I did it the right way.
However, I then proceed to tap on the IRCM harder and harder and by the 4 hit, there came a constant noise (hard to describe, but a dull slightly rough winding-like noise) coming from this area (couldn't been the IRCM), and the noise got a bit more slightly intense and it was a constant noise. I then proceeded to turn the key to off and the noise went away. I couldn't get the noise back though. The fuel pump still not priming.
Like I said previously the IRCM is making the click noise it's suppose to make when the key is turned to the on position, and about 1.5 seconds after that click, there is another slighter click that comes from the drivers side between the wheel and the engine area.
Does that tapping of the IRCM and what it did means that it should be replacded? Where to buy? Cost?
Thanks, again
Also, I forgot to mention that when this noise started, I immediately began to smell fuel, but the pump still didn't prime!!!
Thanks, again
:corn:
