Replacing 3.0L w/3.2L What's involved??
Chrisssssssss
vancouver, BC, canada
OK, so you've read my post on my tick. I am looking at replacing the engine. I am now trying to decide whether or not to replace the Old 3.0L engine with a 3.2L engine. Is this a complicated procedure? Is there any significant modifications that have to be done? I know that there are some flywheel issues, but is there anyone here that has dome this already? What else would I need from the donor car to make the swap? ie: mounting brackets, wire harnesses? Does anyone have a step by step procedure for this? I am finding a couple of these motors around, but if it is not a big deal to swap in a 3.2, I might as well because it has to be done anyhow. If it is too difficult, then I will just put in another 3.0L. Thanks to everyone for the help.
noSHO
ohio is for hustlers
Since a lot of people these days seem to be using the 3.0L heads, I'd assume a little different procedure. All one must do is bolt up the 3.0 heads, correct? No hacking to be done?
drivinhard
Gainesville, GA
Correct.
And frankly there's not much hacking to get a 3.2L head to fit. Just some material to clear away behind the alt bracket and alt bolt, and 1 hole to drill/tap (2 if you think the coil pack brackets needs all 3 of those 14mm bolts).
Can't stress this enough, the 93-95 blocks are all the same. 3.0L is same as 3.2L. everything fits up the same, there is no difference. they come from the same casting.
dan.delargy
