Bryan Kuban
Frustrating late afternoon.
I changed the plugs and wires on my 89. It went a **** of a lot smoother than I thought it would. After wiring the 1st plug I noticed the the boot didn't quite fit tight on the valve cover. I was recommended by someone in the club to get Duralast 4142 wires. I used them with NGK Iridium 5464 bkr5eix11 plugs. He even explained very well on how to run them and what to do. Was pretty easy without taking off the intake manifold. Some small odds and end vacuum lines had to be removed but nothing special and I bought a swivel magnetic socket which made things very easy. Thank you.
I thought to myself I will just get it all done and fire it up and see what happens. If I leak some oil so be it. Ill figure it out on making a gasket or something.
I fired it up and it ran. It always runs rough when I 1st start it up until it runs for about 1 min. Then it is fine. I went to give it some gas and give it some r's. It did fine but I didn't let it run for the full 1st min. Since I didn't it died. I went to restart it and nothing. Tried and tried again and still nothing. I even replaced the M Code and nothing.
Any help on what to look for would be awesome.
Thanks.
Thanks.
