I'm not far into my clutch job and already running into trouble.I removed the driversside half shaft easy.I went to remove the right side and it will not slide out.I'm afraid of tearing a boot or worse.It looks like when I go to remove the tranny I can just slide to the left and the right side half shaft will slide right out.
Will this work?
If not do you guys have any tips for me?
I also messed up and forgot to remove the top two bolts on the tranny before lifting the car.How bad will this bite me?
Taking the tranny out does'nt look too bad once I get past the shafts,but the clutch install may make up for it.
Thanks for any help you guys can give.
Will this work?
