Removing rear exhaust mani on an ATX
zacritz929
slowSHO
toledo, oh
I broke the 2 manifold studs off flush with the manifold.. I figured I have to take the manifold off but I wanted to know if anyone has a diagram of the bolts that hold the manifold to the block. Do you pull it out from the bottom or top?
SHOBlu
Habitual Offndr
New Sharon, Maine
Unfortunately you have to pull the head to remove the manifold. Thats going to be the easiest way. I just did the same thing to mine (see my post in section) but my studs aren't flush.
If anyone knows another way besides removing the head, PLEASE let us know.
Mike93
Go Sabres!!!
Buffalo, NY
You DO NOT have to remove the intake maniold nor the cylinder head!!! The bolts can all be removed from the top...I've done this before...and then drop the exhaust manifold out the bottom. Look at the front exhaust manifold to get and idea of what you're dealing with on the backside. It's easier to remove than you may think...
SHOBlu
Habitual Offndr
New Sharon, Maine
AAAAH... Thank you Mike93! I really don't want to remove the head if my stud repair job goes the wrong way. We'll see this afternoon.
zacritz929
slowSHO
toledo, oh
About how long does it take to remove the rear manifold??? Also how would I get the last little piece of the stud out of the mani???
Mike93
Go Sabres!!!
Buffalo, NY
When I did it I had it out in about 20 minutes. Then onto the benchvise to remove the stud...this part could go smoothly, or like it was when I did it, a complete pain in the a$$.
SHOBlu
Habitual Offndr
New Sharon, Maine
You will need to drill and either chase the threads or tap new ones into the ******. I've had it take from 20 min. to an hour. It depends on if you have the proper equipment or not.
BTW - I went to Ford Parts today to order 2 studs for my ATX manifold and found out that they are an obsolete part and only manual ones are available. I'm not sure if they are the same or not, but they had different part numbers.
Let us know how you make out.
zacritz929
slowSHO
toledo, oh
In the manifold holes not in the head.. Is there an EGR pipe going into the rear mani? Is it tough to get at the nuts for it?
zacritz929
slowSHO
toledo, oh
I started today. First I took off the heat shield. Then I started removing the manifold ntus and got all but the farthest passenger side nuts off and then I remember to take care of the EGR bolts. I got a wrench on one of the EGR bolts and kept giving it about an 1/8 of a turn with the wrench and it didnt seem like it was making any progress but then it snapped. Now I have to broke studs/bolts that Ill have to remove. The other lower EGR bolt seems like it will be hard to get at also the last manifold nut seems liek it might be hard to get at too. What did you guys do to get these two bolts out?? BTW all this took me about an hour, so far it seems simple.
zacritz929
slowSHO
toledo, oh
Today I got the manifold out.
I actually pulled it out of the top but i already unbolted the y pipe. I wasnt able to get the y pipe completely off the car, it was kind of jammed. Now it seems like the y pipe doesnt want to go back up.
Do I have to fiddle around with it to get it to line up in the right place??
