if you're going thru the trouble of dropping the pan to fix leaks, I'd recomend spending the extra $40 on a set of rod bearings. Even though I have pulled bearing out of 140k mile MTX's that looked fine, whe you're in there it makes sense to do it. onnly adds about 2 more hours on your back.
RCM automotive hasthe best price for RB's that I have seen on ebay at $39.99 a set. You also have to have a good TQ wrench, assembly ****, and safteyglasses (for drippig oil in your eyes)
I have coated my rod bearings going in to my 3.2, as well as coating my shim buckets, all tranny internals, and will be pulling my cams out over the winter to coat them too. (after they are broken in)
If you deciide to dorod bearings I could dry film lubricant coat them them for you for $20. DFL addsa layer of friction reducing material on the bearing that has been shown to dramatically reduce friction and wear, and it is also an oil retaing coating that will mean more oil will stay on the RB's after the engine has been shutoff, meaning more lubrication on startup. Here is the info from the coating manufacturer's website.
"Dry film lubricants, also known as solid film lubricants, provide a lubricating film that reduces friction, inhibits galling and seizing and in some instances can aid in dispersing heat. The appearance is generally a charcoal gray and takes on a sheen upon burnishing. They are slippery and provide an extremely low coefficient of friction.
The two most important components are the binders and lubricating ingredients. Without a good binder the coating will not stay in place and will simply cold flow or buff off in operation. Similar coatings using the same pigments but different binding systems can show a wide variation in load carrying abilities, ranging from 100,000 psi to over 350,000 psi . The pigments determine the actual lubricating potential. PTFE, as an example, is listed as having the lowest coefficient of friction (COE). However, under high speed and load, the COE of PTFE degrades while that of MOS2 (Moly) improves, until it is significantly better than PTFE. Selecting the proper ingredients can make or break a coating.
One of the obvious reasons for using a lubricating coating is to reduce friction, which improves wear, extends part life and frees up H.P. normally lost to friction. A second major benefit is a reduction in part temperature. This is especially important to such parts as valve springs. Here the pigment choice is critical as certain ingredients can trap heat in a part. Not all coatings are created equal."
