removing AC compressor on 3.2
SHO Continental
Moderator
Northridge, Cali
Does anyone know how to remove the compressor without dropping the engine? I took out the center bolt and there isn't any room to put in the puller between the body and the pulley.
Any ideas?
SHOtimer
#2910
Santa Clarita, Ca
I just did this a little while ago when I replaced my compressor. You need to pull the fans, and the radiator. I pulled the alternator to make it easier, but i'm not sure if it is necessary.
Good luck,
Doug
