Remote Start Install!!
93SHOCOOL
Cincinnatti, OH
I just bought a remote start (with remote keyless entry) for my 93ATX and I was wondering if anyone has done this on their own before and has any hints or trick!! Also, a wiring diagram would be very helpful if anybody has one!!
T
ThatSHOkid
Guest
is it possible to do on a MTX
1993 White/Tan SHO MTX 97k Miles
[*] Performance: Sho Shop Y Pipe * Coneless & Boxless * K&N Filtercharger * Superchip Performance Chip
[*] Appearance: Colgan Custom Bra * "SHO" Windshield Banner * Blacked Out "SHO" Lettering * Ventshade Sunroof Wind Deflector & Vent Guards * GTS Headlight Blackouts
[*] Audio: Sony 10 Disc Changer
[*] Lighting: Eagle Super White Headlights * American Products Company Super White Reverse & License Plate Lights * Blazertech Foglights
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (a NESHOC member)
"Drive it like you stole it!"
RickieFrat
La Cosa Nostra
State of Corruption - RI
NO ... the clutch needs to be pressed in to start car.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
RickieFrat
La Cosa Nostra
I know the wires .... give me till later today to post it. Its long.
fredhurderjr
www.neshospecialists.com
Yes, it IS possible to do on an MTX, but it usually requires a special module, and most installers will NOT do it, just like most places won't do a carburetored car (though it's doable as well). It's a lot more expensive to do it as well.
Essentially, you have to always leave the car in N and keep the p-brake on. I don't like that idea at all, personally.
93SHO
Littleton, CO
I suppose it'd be possible if you had some sort of machine to push down the clutch pedal. Or you could not put the car in gear, and leave a cinder block on the clutch pedal... just some suggestions
1993 MTX.
Mods - Quaife, Baer brakes, 2" dual exhaust, Dynomax mufflers, H brace, Koni struts, front camber/caster plates, rear control arms, SHO shop springs, solid aluminum radiator, big bore butterflies, cold air, K&N, kevlar clutch, high flow cats, 80mm MAF, front and rear strut tower braces, 16" ROH Sniper wheels, BFGoodrich KDWS 225/16/50 ZR4 tires, and LPM
Sitting in basement - Garrett turbo BURNOUT (who knows...)
Rob94
Northbridge MA
All you have to do to make it work on a mtx is disable the neutral safety switch, which is under the dash. Take a look under there, it should be right above the clutch pedal....pull the wire to the plunger type switch, and you're good to go. Only problem is you MUST leave the vehicle in neutral all the time. If you forget and leave it in gear and try to remotely start it, well, use your imagination. Also, keep your fingers crossed that your parking brake doesn't freeze solid on cold nights, cause then you are going nowhere fast.
Rob
White 94MTX
K&N Filter otherwise stock
S
SHOFF
Guest
You can use a remote start with a manual trannsmission its vvery easy to do just connect the wires together on the clutch saftey switich. The little trick i learned on doing them is( on DEI remote starts only}connect the netural saftey wire from the rempte start to the emergency brake wire this way it will only start if the emergence brake is pushed down. as far as wires gothese should be the right ones but they are off the top of my head
starter .......red with light blue stripe
heater.......gray with yellow stripe there may be more than one power all of these up usually one is for heater and one is for ac
ingition......usually red with a green stripe
battery........yellow orlight greeen with a purple stripe
brake............light greenwith red stripe
remember to check all wire to make sure they are right before connecting, ford changed wire colors all the time
Sho shop cams
80mm mass air
big bore butterflys
underdrive pullys
strut bars, front and rear
cold air intake
high flow y pipe and cads
18 inch quatem tek wheels
eibach springs
2 tvs
dvd
playstation
5000 watt system
www.shoracing.com/pix/g2/donnyc_93sho.jpg
RickieFrat
La Cosa Nostra
Sorry bout the wait ... Hope This Helps.
Remote Starter Wiring Colors For 1992-94 Ford Taurus
Start: WHITE/PINK
IGNITION SWITCH HARNESS
Ignition #1: RED/LIGHT GREEN
Ignition #2: GRAY/YELLOW (14 AWG)
IGNITION SWITCH HARNESS **
Ignition #3: GRAY/YELLOW-2WIRES
Accessory: BLACK/LIGHT GREEN
Brake Light: RED/LIGHT GREEN (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach Signal: TAN/YELLOW, WHITE/PINK
OR GRAY/ORANGE IGN. SWITCH HARNESS *
Parking Lights: BROWN (+)
HEADLIGHT SWITCH OR DRIVER KICK PANEL
Headlights: RED/YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm Disarm: N/A
Diesel Glow Plug: N/A
Clutch Bypass Wire:
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: YELLOW (5)
Starter ****: WHITE/PINK
Ignition +12 Volts: RED/LIGHT GREEN
Dome Lights/Superv: BLACK/LIGHT BLUE (+)
DRIVER KICK PANEL OR AT PIN SWITCH
OEM Horn: YELLOW/LIGHT GREEN (-)
RELAY BEHIND CENTER OF DASH ON BRACKET
Power Lock: PINK/YELLOW
DRIVER'S KICK PANEL ***
Power Unlock: PINK/LIGHT GREEN
Trunk Release: PURPLE/YELLOW (+)
AT KEYLESS MODULE (SEDAN)
Alarm Input Wire: BLACK/LIGHT BLUE (+)
[This message has been edited by RickieFrat (edited 12-26-2001).]
93SHOCOOL
Cincinnatti, OH
RickieFrat THANK YOU SOOOOOOOO MUCH!!
I am doing it tomorrow, I'll update you on how it goes when I am done.
thanks again!
Shoboy3
I am bringing this thread to the top to avoid posting another thread.
Would it be possible to use the 2nd channel output (normally used for trunk pop) for the gas door pop?
Anyone know what color wire I would be looking for, and where?
ericwick19
saginaw, MI
isnt the gas door release mechanical?
if so, you can not use the output unless you figure a way to rig up an actuator to the mechanical cable gas door popper. if it is electric, just test the wires going to the switch and find if it is (-)or(+) trigger, and since the output coming from the remote start module only supplies a (-) 200milliamp output (most common, im using dei remote starts as my basis) you will have to wire up a relay accordingly
Hambony
Houston, Tx
It is possible to install a remote start on a MTX but I would recommend against it. My friend had one put on, fine for a year until one day he slipped and forgot. New bumper and higher insurance for him, new axle, body panels, and headache for the person he hit. Luckily it was someone he knew so it wasn't too bad. But anyway, it is cool, but you will kick yourself first time you forget and watch the fireworks.
buechine
Ontario, Canada
Hambony:
I have one in my Manual car. Before I turn the ignition off I have to push the brake petal hold the clutch and pull up on the parking brake after this I have to push the button on the remote(ehile still holding my feet on the clutch and brake) which unlocks the doors and I am able to take my feet off the petals and take the key out while the motor still runs--Then when I get out of the car and close the door I push the button again and it locks the doors arms the alarm and shuts the engine off. This way there is no possible way that the car will be able to start if you haven't shut it off correctly and won't damage anything by making a mistake. It's actually really easy to use just takes a lot of words to describe it. It cost me if I remember around $300 (200 US)for the unit in Canadian installed. Although it took my installer 7 hours to do and he said that next time he would definately charge more and he gave me a real good deal in the first place.
