Remote car starter?
93 Fo SHO
Hayward WI.
I was wondering if anyone here installed there own remote car starter? If so was it a pain? I never installed one so I dont have clue what to expect.
ericwick19
saginaw, MI
ive installe a couple of them inluding one on my SHO ATX. they are quite easy, if you need the wire colors and where to find them, lemme know
nothingtoseehere
Keep in mind that if you have a MTX, you have to leave the car out of gear when parked...otherwise the remote start is useless. I have always been afraid to put one on my car for that reason...I always leave the car in first when parked though...
-RANDY-
1993 Green/Mocha MTX
No Mods as of yet
Famous quotes from Heather (casca):
"Imma kick your sandal wearin ass for that comment" - still hasn't happened
and
"I can't, my asscrack is showin" - hey what can I say, go bowling......
FAST4DR
I have a Autostarter on my MTX and I haven't had the chance to rig up a neutral switch so the system knows it is in neutral, but I have a couple ideas. I have to leave my car in neutral all the time. It is kinda dangerous having a car starter on an MTX car. I tested it with the car in gear and emergency brake on, and it will definately start the car and start chugging away. Could **** someone if accidently left in gear.
William
93SHOCOOL
Cincinnatti, OH
I just finished installing a remote start on my 93ATX. It isnt that hard to do, if you have some sort of mechanical/electrical knowledge you should have no problem doin it. The only problem I ran into was finding a gramet to run the hood-pin switch and the tach wire through. Besides that it was pretty simple. In my opinion it is a good investment Remote Starter Wiring Colors For 1992-94 Ford Taurus
Start: WHITE/PINK
IGNITION SWITCH HARNESS
Ignition #1: RED/LIGHT GREEN
Ignition #2: GRAY/YELLOW (14 AWG)
IGNITION SWITCH HARNESS **
Ignition #3: GRAY/YELLOW-2WIRES
Accessory: BLACK/LIGHT GREEN
Brake Light: RED/LIGHT GREEN (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach Signal: TAN/YELLOW, WHITE/PINK
OR GRAY/ORANGE IGN. SWITCH HARNESS *
Parking Lights: BROWN (+)
HEADLIGHT SWITCH OR DRIVER KICK PANEL
Headlights: RED/YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm Disarm: N/A
Diesel Glow Plug: N/A
Clutch Bypass Wire:
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: YELLOW (5)
Starter ****: WHITE/PINK
Ignition +12 Volts: RED/LIGHT GREEN
Dome Lights/Superv: BLACK/LIGHT BLUE (+)
DRIVER KICK PANEL OR AT PIN SWITCH
OEM Horn: YELLOW/LIGHT GREEN (-)
RELAY BEHIND CENTER OF DASH ON BRACKET
Power Lock: PINK/YELLOW
DRIVER'S KICK PANEL ***
Power Unlock: PINK/LIGHT GREEN
Trunk Release: PURPLE/YELLOW (+)
AT KEYLESS MODULE (SEDAN)
Alarm Input Wire: BLACK/LIGHT BLUE (+)
Start: WHITE/PINK
(There is also an easier way to get the tach signal, on the DIS module on the pass. side of the upper-intake, use the gray-yellow/tan wire on the backside of the unit. You have to peel back the blackloom and soder the new tach wire to the factory tach wire off of the DIS module)
Clutch Bypass Wire:
Can't tell you that SORRY!!
