Regulator Seals
tportman
Lombard, IL
On a 1990 SHO, the Ford dealership misdiagnosed the regulator as bad and tried replacing it (I know the original is fine because I pressurized the regulator on an ASNU machine and it held to 38psi). When that didn't solve the problem, they put the old one back on and let the thing go even though the regulator now leaks around the fuel return line. Is there any way to get the regulator seals for the 1990 SHO without purchasing an expensive kit? I'm specifically referring to a copper washer and a captive o-ring in a copper washer, each on one side of the fuel return line? Thanks for your help.
