biker889
1994 SHO 161k 5 spd
I bought this from the original owner about 2 years ago, he used mobil one since day one, i have a lot of original paperwork including the window sticker.
parts:
fuel pump, filter
control arms, ball joints, tie rods,front sway bar links, right axle
clutch, flywheel, clutch cable
plugs, wires, valve cover gaskets, intake gaskets, thermostat, coolant sensors, timing belt, water pump, crank sensor, mass air sensor, ac charged and working. Rear brake calipers, pads, hoses, parking brake cables. Valve lash done approx. 120k. Probably more i cant remember,
Performance:
dynomax exhaust(single exit) ,rear energy suspension strut rod bushings
intrax lowering springs, koni adjustable struts, all new strut mounts and boots, shorty shifter, 96+ front brakes and pads and original wheels not on it now. custom powder coated cobra front calipers and 13" rotors and cobra R wheels with sumitomo tires.
Cons:
needs front end alignment
driver seat bolster torn, crack on right corner of dash, leaks and burns about 1-2qts every oil change
rear bumper was spray painted i think? i have another bumper. couple dings, scratches.
Asking $2900 with cobra wheels and brakes, $2000 without.
Any questions e-mail or pm me, if you want specific pictures, let me know of what.
-Dan
E-mail is best [email protected]
267-733-8374
parts:
fuel pump, filter
Performance:
Cons:
-Dan
267-733-8374
