OK, i am new here, and this is my first sho. I have a 93 and the rear wheel makes a klunk! it is loose when i push on it, however, all the lugs are tight. rumor has it it could be a bearing. has anyone attempted this before?
There is an off chance this could also be the strut cups.I`ve had them worn so badly that the top of the strut assembly was able to pivot 1/2".The bearing actually pulled away from the rubber housing.The aforementioned ideas can be looked at much easier than this though.ccoenen
[QB]I have a 93 and the rear wheel makes a klunk! it is loose when i push on it, however, all the lugs are tight.[QB]
Ditto and very well said! thumbs_uSHOooo:
The first step I'd recommend would be to pull the tire and make sure everything is connected and intact. You could have a broken sway bar end link, strut mount/bearing, coil spring, loose/bent control arm, etc.
I personally doubt the wheel bearing would cause the clunk and looseness you describe. Once the wheel is off, grab the rotor and see what movement you can observe when you wiggle it. That might help identify the source of the clunking, as well as the reason for the movement. If you set the parking brake, you shouldn't be able to rotate the rotor, and there shouldn't be much (if any) rotor movement on the hub as long as your parking brake is working properly.
when i replaced the hub nut on my right rear, i did not have a metric socket large enough, but i found a 1 7/16" that fit nicely...which, 1 7/16" translates to 36MMxssho1:
36mm is HUGE, u sure its not 30mm?
