rear spindle
Banshee
New York
Hey guys. My 94 atx needs new struts and i snapped the pinch bolt. Started to drill it out and it's not going well so I want to grab another spindle/knuckle from the jy. Any ideas what year rears will fit? I haven't seen any sho s but there are a couple gen 2 that might be a pain to get off. Lots of gen 3 up there
Banshee
New York
Update. I found a thread that says any 93-95 with disc and abs taurus/sable. That means no gen 3. Is this correct?
TimboSHO
Intermediate
Wyoming, MI
That would be correct. Remember to always use heat to get the pinch bolts out in the rust belt or they WILL snap. Learned that years ago the hard way.
Banshee
New York
Yeah. Just got back from the my and they won't let me take any kind of torch in so all I had was pb blaster. Only 2 cars there that will work and one is all ready snapped off. Sprayed the last one real good and took everything I could apart. Ill go back Monday if I can't find one online for sale
You could just pull it with the whole strut or cut the strut and work on removing the bolt or what's left at home on a bench. People have drilled them out and if the threads are damaged they use a nut and bolt instead
crystizel
