Rear shocks for 2010 sho
FOSHOMATT
Homer Glen, IL
Hey guys just a quick question I’m about to replace my rear shocks since they are leaking but I’m having trouble on which ones to purchase on rock auto. 1 shock has suspension a,b,e and the other one says suspension c and I’m just confused on which ones to buy.
Christian
Chilliwack BC CANADA
I've had good experiences with Rockauto. If you just call them, they'll take care of you. I've had similar issue as yours with my LS460.....lots of parts for different optioned cars.
I just had a quick look and don't see what you did. You're offered 3 choices for "original ride quality" and one for "heavy duty". For OE, you have PP (KYB) and Motorcraft for red calipered cars and Motorcraft for non red calipered cars.
Also, when you decide to buy, look for online discount coupons/codes. I've saved a lot of $$that way.
FOSHOMATT
Homer Glen, IL
I like rockauto as well unless I need something quick I go to the dealer. But I posted a pic for what I see. I saw the 2013’s with painted and non painted but the 2013’s don’t fit on the 2010’s I’ve heard. M
jman1200
Ontario
I had that same question some time ago. Went to the dealer, parts department and asked them to look up my VIN number and tell me. Mine is D.
b4black
IL
Call RockAuto? They don't take calls. ALL customer service is through on line forms. I stop using them when they screwed up my order and there was no good way to straighten it out. Too bad, I used them a lot.
FOSHOMATT
Homer Glen, IL
Well I gave ford a call and they told my my suspension was D and I do not see either of those on rock auto or fords website.
You plugged in the VIN on Ford's website?
https://www.ecoboostperformanceforum.com/index.php/topic,5295.msg84452.html#msg84452
2010-12 SHO
1 CG1Z-18125-A Shock Absorber
Shock, RIGHT/LEFT
AWD, 2010-12, W/ SUSP. CODE D
$138.25 $87.45
CG1Z-18125-B Shock
Shock, LEFT/RIGHT
AWD, 2010-12, W/ SUSP. CODE C
$138.25 $87.45
Shock, LEFT/RIGHT
AWD, 2010-12, W/ SUSP. CODE E
$138.25 $87.45
2013+ SHO
1 DG1Z-18125-F Shock
Shock, LEFT/RIGHT
AWD, 2013-19, W/ HD SUSPENSION
$108.96 $68.92
DG1Z-18125-A Shock
Shock, LEFT/RIGHT
AWD, 2013-19, W/ O HD SUSPENSION
$128.45 $81.25
jchaase
Kasson, MN
I have been told one of my rear shocks is leaking - looking to do this replacement myself. Is it really as easy as the service manual makes it look? I searched around on YouTube, and there isn't a video to be had about it. No posts here with process.
