Rear Motor Mount
jammin
Chicago
Does anyone know procedures for removing and installing rear motor mount? :oogle:
naval-avi8or
Chesapeake, VA
RH FRONT OR REAR INSULATOR 3.2L ATX
1. Remove lower damper attaching bolt from RH side of engine, Fig. 3.
2. Raise and support vehicle, then place suitable jack and block of wood
under engine.
3. Remove nuts attaching roll damper to engine mount, then the roll damper.
4. Raise engine enough to unload insulator.
5. Remove two attaching bolts, then insulator from engine bracket.
Reverse procedure to install.
Support Insulator, Rear Engine 3.0L MTX
Removal
1. Raise vehicle on hoist. Refer to «Section 00-02».
2. Remove the nuts retaining the front engine support insulator and front
engine support insulator to the front sub-frame.
3. Lower vehicle.
4a. Use Three Bar Engine Support D88L-6000-A or equivalent to support
engine. Install J-hook on the generator bracket. Raise the engine about
25 mm (1 inch).
OR
4b. Raise and support vehicle, then place suitable jack and block of wood
under engine.
5. Loosen retaining nut on the front engine support insulator and heat shield
assembly.
6. Raise vehicle on hoist.
7. Remove front engine support insulator retaining nut. Remove front engine
support insulator and heat shield assembly.
naval-avi8or
Chesapeake, VA
under engine
Removal
3. Lower vehicle.
25 mm (1 inch).
OR
under engine.
assembly.
in red text.
