Rear main seal
srfdude
Oceanside, CA
Is there any significant difference between dropping the oil pan on a 3.2 vs. 3.0? I'm familiar with the tricks of the 3.0; looks like the engine is a little farther forward in the ATX. Does this cause any other problems? Also, does the pan have to be dropped to remove tranny/change rear main seal? Damn 50K SHO has a rear main leak; not much but enough to be annoying and leave drops on the carpet in my garage.
Mike
PMD Power
Watauga, Texas
well I do know you do not have to drop the pan to do the rear main seal... once the tranny is outta the way it is pretty simple
RI-SHO
B to the BANNED
Pawt., RI
While your there it would make it easier to change the oil pan seal as well only about $14 at AZ.
srfdude
Oceanside, CA
Well, I would change it if I did the work, but trust me, dropping an ATX isn't something that's going to happen in my garage. I have a pretty good trans shop; I am thinking about having them install a trans-go shift kit into the tranny, and the same time change the seal.
Mike
rangerj
Brunswick, Ohio
RI-SHO
The man has carpeting in his garage, you don't think he does his own work, do you? I mean CARPETING in the GARAGE buddy, think about it!
(tongue planted firmly in cheek) (but still a bit "cheeky") rangerj
It is Monday isn't it?
RI-SHO
B to the BANNED
Pawt., RI
I just read that lol, that sounds like something I would do if I owned a house.
