Rear Camera Delay
2010sho
Midwest
Does anyone know how to set the delay for the rear camera when shifting into Drive. The Manual says go to settings on the Nav screen, but I'm seeing a setting to switch the delay from off to "on"
roadhammer
Mo.
If you turn it to on it will stay in camera mode for some time after you shift to drive. there are no other settings.
2010sho
Midwest
Weird,
Mine immediately goes right to the Nav screen.
However on page 25 of the Navigation manual it tells you to set the delay under settings next to the contrast settings
LotusDriver
Rocky Hill, CT
Put the car in reverse, on the screen on the bottom left hand corner y ou will see "Settings". As long as you are not moving, go into settings from there and adjust the delay.
LotusDriver
Rocky Hill, CT
Anytime. Personally I want the camera to go away as soon as I take it out of reverse. I want to be able to tune the radio right away. (usually you use reverse when you first get into the car). I see no point at all of keeping the camera screen on, once I'm moving forward. It just seems silly to me.
