Croaker
Today I had to change the rear brake pads. We (yes, I had help), noticed that the inside pads on both sides were worn more than the outside pads. The outside pads had at least 60% of life left while the inside ones were about 10% or less. 2 of the Caliper pins (slid in and out with the lil'rubber boot) were rusted pretty tight and not nearly as fluid in motion. In our thinking that was the reason why the pads didnt' wear evenly.
1.) Can those pins be replaced or does the whole caliper need to come out?
The Caliper has 2 parts. 1 that hold the piston and the other that bolts to the wheel/strut (whatever you call it). Couldn't break lose the ones mounted to the car (the one without the piston). We did get the new pads installed. I don't drive the car everyday but eventually and probably rather quickly the pads will need to be changed again. I'm looking for some ideas on what to do next.
Thanks in advance,
-Kevin
Thanks in advance,
-Kevin
