rear brake problem
SHONUT91
Cameron,Mo.
The problem I am having is with my right rear brake caliper(I think).Here is everything that I have replaced e-brake cable,slider pins,rotor,pads,rubber brake line,and hard line from wheel to proportioning valve(the end twisted off when I tried to replace the rubber line.)After all of this the caliper still sticks,enough that I have brake dust on the wheel after only a couple of days.Am I correct to think it may be the caliper itself or could it be something else?For those that may ask(NO,I have never forced the piston back in with a c-clamp I have the tool for the job.)Sorry for such a long post I am getting frustrated with this problem any help will be appreciated and Thanks in advance. shoot
Tom M
US
I had the same problem last year. I think my problem was the ebrake mechanism in the caliper was sticking. I replaced the caliper and all is well.
Be aware that the ebrake return spring is difficult to swap over to a new caliper. I returned the first caliper that I bought and found one that had the spring already installed so I wouldn't have to deal with it.
Good luck!
Shoman94
Maine
I had the same, and replaced all the same as you. What I did to solve it was disconnect the e-brake cable...this made me certain that it was the e-brake side of things. From here I found it was all in the adjustment of the e-brake cable at the adjuster under the drivers door. What was happeneing was my e-brake would not release all the way if they were even the slightest bit too tight. Up on jack stands, I kept trying it, then loosening, the trying it, then loosening until it was fuly released. No issues since.
Good luck
pjtoledo
'ol man in the SHO
toledo,ohio,usa
SHONUT91:
We need some clarification and info. Some brakes are just dusty, do you really have a problem? Is the brake actually sticking? Did you jack it up and see if the wheel turns freely? OR, after driving for a mile or so, is the rotor hot? Get your fingers close to it, you can easily feel the heat from a stuck rotor. Compare the two rear rotors.
Perry Toledo,Ohio
SHONUT91
Cameron,Mo.
Yes I have jacked the car up after driving it for awhile,and no the wheel will not turn,and yes the rotor is extremely hot after only a few miles of driving compared to drivers side.Drivers side will turn and is not as hot as passenger side.I have checked the e-brake cable adjustment and it is fine.The cable itself is releasing all the way,is there any way to tell if the e-brake within the caliper is releasing?
tomw
Rochester, N.Y.
If you have ruled out the parking brake issues, there are two possibilities. One is a bad caliper (piston not retracting and letting go of the rotor) . Two is a bad rear porportioning valve that is trapping pressure in the caliper. If you open the bleeder and the brake frees up, this could be your problem.
Tom W
93 Red ATX
92 MTX
stevetatro
Cincinnati, Ohio
There's another possibility, which I've heard of happening a few times: a bent/warped caliper bracket.
Obviously if the bracket gets bent the slider pins are crooked and no matter how much grease you have inside the little boot they won't budge.
Just a thought. If you've replaced everything else this may be the culprit. I replaced mine yesterday with one I pulled out of a junkyard for $10.
Good luck.
