Rear axle noise
SHOred
North Carolina
I just bought my first SHO. It is a red 93 ATX. When moving there is a rattle coming from the rear axle area. Is this the rear struts making the noise? If not what could it be. I have had the car on the lift and can not make the noise by bouncing the car or beating on anything. Everything appears to be tight. What can it be? Thanks for any help you can give.
SHOred
Mr Anonymous
Tire Wall
If you have rear axle noise on a SHO, you must have one of those special one-of-a-kind RWD ones! :evilgrin:
Sorry, I couldn't resist!
It could be a wheel bearing or one of the brake calipers hanging up. While driving about 20MPH or so, make some abrupt sharp turns in both directions. If the noise goes away, it's a definitely a wheel bearing. If not, the next thing to check would be the sliding pins on the calipers -- they often seize up. You could also have a parking brake sticking.
Start with the bearing test and let us know what you find.
Welcome to the forum! :thumb:
smokin joe
Milwaukee WI
Also It could be a rear strut top, does it make the noise over bumps? if so then thats prob what it is, and yeah sho's are FWD not RWD so no rear axles
SHOred
North Carolina
Thanks guys. It does make the noise when moving on a rough road so it might be the struts. I'll get it on the lift and check it out real good.
