Reading Data from Computer on a 95
Duff
Box Elder, SD
I have a mastertech for accessing all types of PCM's, and have been unable to read the data list for the SHO (95, MTX, federal emissions). I know my 93 GL lets me in to do this, and I was wondering if anyone had attempted to connect to the computer at all, and if anyone had any luck in accessing the data list.
Any help is appreciated
David
fredhurderjr
www.neshospecialists.com
I have an Acctron ScanTool for the Ford EEC-IV ($300). Mine reads, resets, whatever the PCM & ABS computers with no problem. I also have a 95 MTX.
Is the connector hooked up correctly? Mine requires both the large connector & the single pin connector to be attached. Perhaps you have a broken wire on the test connector on the firewall?
Good Luck!
White 95 SHO MTX
"Jezebel"
Spends more time in the shop than in the driveway
Teases me with occasional great runs
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger (12psi on the way)
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
Hi-Revs Jr. Clutch
SHO Shop Y-Pipe & Cat-Back
120k miles, NOT RUNNING YET (Grrrr!)
