Reading Check Engine Codes
flosho
Shooting Flames
wisconsin
Well, I do everything the link says... When I turn my car on.. it goes through the fan, and the fuel pump, then the CEL blinks for a second. Then, there is a pause and it goes like this:
Blinke *pause* Blink *pause* Blink
Then it does the same pattern AGAIN. After that it goes into some codes I think I wrote them down correctly but some of them aren't even on the list, so obviously I misread something! Last nite I cleared the codes the way Scott said, that was to pull the connecter in the middle of the scan. I haven't been able to try the scan again. Later tonite, I will try and bring back some codes.
I guess my real question is, what does the two 111 codes mean?? right in a row.. and does anyone got 'tips' to reading these codes?
Thanks,
flo
Yamaha V6
SHO Enthusiast
Rhode Island
The system cycles / repeats the code listings.
111 = system checks ok
then it cycles in case you missed it the first time. :)
flosho
Shooting Flames
wisconsin
lol. See this is where I get confused. My CEL comes on every now and then. So why would I get a 111 code? I tried clearing them, maybe it didn't work.
But according to what you are saying, my only code is 111, and the rest are past codes/problems?
Thanks
flo
flosho
Shooting Flames
wisconsin
Oh yea, I only did the KOEO not the KOER or whatever.
Maybe I should do the other test huh?
Thanks
flo
Yamaha V6
SHO Enthusiast
Rhode Island
If you wipe the codes, that's what you'll get. Make sure that the car's hot, run & codes again, especially AFTER your next CEL.
Yeah, KOER works differently than KOEO. :)
flosho
Shooting Flames
wisconsin
My bad, I haven't read the codes after I tried clearing them I am going to do that within the hour
thanks
flo
flosho
Shooting Flames
wisconsin
Ok I just ran a test I got:
636
636
then
111
111
so All I have to worry about 636 with is something with the transmission oil sensor.. Any help with this???
Thanks,
Flo
