Readiness Checks
Izzmo
SHO Enthusiast
Kansas City, KS
Anyone know what the readiness checks are that are performed when the car is first started?
I either get the P1000 that the readiness checks are incomplete or a partial one saying that only 6 of 8 (or 9.. can't remember the total # of checks) is complete.
popsracing
EFI Calibrator
Rochester, NY
What checks aren't passing? How many miles have you driven after reseting the bat or clearing the codes?
Izzmo
SHO Enthusiast
Kansas City, KS
I have gone a good 50 miles since the last reset (about 2 days ago), but that code is pretty permanent from what I can tell.
I'm not sure what checks have no completed, it just tells me that it has only completed 6 of them.
Izzmo
SHO Enthusiast
Kansas City, KS
I don't know if you are reading my posts or not.. for the last time, I don't know what checks are not completing.. I only know that 6 of them have completed and it hasn't moved from there for months.
I have an SCT tuner, and also went to AutoZone and O'Reilly's and they all say the same thing, none of which giving me what checks have not completed.
popsracing
EFI Calibrator
Rochester, NY
Without that information I can help you, do you know someone with a scanop or matco scan tool, generally it will do the readiness checks.
Izzmo
SHO Enthusiast
Kansas City, KS
I don't. Unless another O'Reilly, AutoZone or Advanced Auto has one.. but I doubt they have different ones from their other stores.
popsracing
EFI Calibrator
Rochester, NY
If you were closer I'd hook you up to my matco, B.E. will also show the readiness codes but the mongoose obdII hardware is required.
Izzmo
SHO Enthusiast
Kansas City, KS
Yeah, that would be nice! It doesn't affect anything really, just more of a irritative error that should go away.
1997 PCED OBDII-A SECTION 2A: Diagnostic Methods
Drive Cycles
Description of OBD II Drive Cycle
The purpose of the OBD II drive cycle is to execute the OBD II monitors and identify any concerns with the OBD II system. The DTC P1000 code will be erased of all OBD II monitors have completed during the OBD II drive cycle.
WARNING: STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
The scan tool will be used to observe the status of each OBD II monitor at the completion of the OBD II drive cycle. The completion status of the exhaust gas recirculation (EGR), heated oxygen sensor (HO2S), evaporative emission (EVAP), secondary air injection (AIR) (if applicable) and catalyst efficiency monitors can be monitored during the OBD II drive cycle by viewing the On-Board Readiness Menu on the scan tool.
For the description and operation of each OBD II monitor, refer to Section 1A.
Vehicle Preparation for OBD II or Monitor Repair Verification Drive Cycle
Note: Vehicles equipped with power take off (PTO) must have this system disengaged before proceeding. Verify by viewing the PTO PID for OFF status.
1. Attach a scan tool and access the ECT, FLI, IAT PIDs.
o Verify the IAT PID is between 10-38°C (50-100° F).
o Verify the FLI PID is between 15% and 85% (only available on EVAP Running Loss systems).
2. Warm the vehicle until the ECT PID reaches a minimum of 54° C (130°F).
3. Clear all DTC's with the scan tool by pressing clear with the key on engine off. P1000 will remain. Leave the key in the ON position, and start the vehicle.
4. Access the On-Board System Readiness Menu on the scan tool to view the status of the OBD II monitors.
5. Proceed with the OBD II Drive Cycle or selected monitor repair verification drive cycle. Once started, the engine must not be turned off.
OBD II Drive Cycle
Note: The IAT PID must be between 10-38°C (50-100° F) during the OBD II drive cycle to enter into all the OBD II monitors. The FLI PID must be between 15% and 85% at all times.
1. Drive in stop-and-go traffic with at lease 4 idle periods (30 seconds each) while observing the status of the OBD II monitor on the scan tool. If the exhaust gas recirculation (EGR), heated oxygen sensor (HO2S), evaporative emission (EVAP), secondary air (AIR) (if applicable) or catalyst efficiency monitor have not completed, drive on the highway at a constant speed over 64 km/hr (40 mph) not to exceed 104 km/hr (65 mph) for up to 15 minutes. Heavy accelerations, sudden decelerations and wide open throttles are not recommended. If the scan tool sends out a three pulse beep at any time, the OBD II drive cycle has completed.
Note: Vehicles equipped with the EVAP purge flow system or EVAP vapor management flow system monitor do not require EVAP monitor completion to clear the DTC P1000 (refer to Section 1A for each monitor description).
If the exhaust gas recirculation (EGR), heated oxygen sensor (HO2S), evaporative emission (EVAP), secondary air injection (AIR) (if applicable) or catalyst efficiency monitor has not completed, perform the corresponding monitor verification drive cycle in this section.
2. Bring the vehicle to a stop and retrieve Continuous Memory DTCs to verify the DTC P1000 has been erased. Refer to Section 4A, Diagnostic Subroutine DSR6 .
Monitor Repair Verification Drive Cycles
Comprehensive Component Monitor Repair Verification Drive Cycle:
1. Refer to and complete the Vehicle Application Preparation For OBD II Drive Cycle before initiating the following repair verification steps.
2. Start the engine and go through the entire OBD II Drive Cycle until the Comprehensive Component Monitor shows the completion status by clearing the code P1000 on the scan tool.
3. If the entire OBD II Drive Cycle has been performed and the Comprehensive Component Monitor check has not completed, rerun Quick Test . Refer to Section 4A, Diagnostic Subroutines, DSR 1 .
EGR Monitor Repair Verification Drive Cycle:
1. Note: The ambient air temperature or IAT PID must read a minimum of 0°C (32°F) to initiate the EGR monitor.
Refer to and complete the Vehicle Application Preparation For OBD II Drive Cycle in this section before initiating the following repair verification steps.
2. Start the engine and drive the vehicle for 6 minutes.
a. Drive in stop-and-go traffic for 5 minutes with at least two idle periods.
b. Accelerate to 72 km/h (45 mph)(56 km/h [35 mph] on ******/Tracer at more than 1/2 throttle). Maintain speed for 1 minute.
3. Rerun Quick Test . Refer to Section 4A, Diagnostic Subroutine, DSR 1 .
EGR Monitor Repair Verification Drive Cycle For Probe Only:
1. Refer to and complete the Vehicle Application Preparation For OBD II Drive Cycle in this section before initiating the following repair verification steps.
2. Start the engine and drive the vehicle for 24 minutes.
a. Drive in stop-and-go traffic for 19 minutes with at least four idle periods.
b. Accelerate to 64 km/h (40 mph) at more than 1/2 throttle. Maintain speed for 1 minute.
c. Accelerate on highway to 89 km/h (55 mph). Maintain speed for 4 minutes.
EVAP Running Loss Monitor System Repair Verification Drive Cycle:
1. Perform the Preparation for OBD II Drive Cycle section.
2. With the scan tool, verify the FTP V PID reads between 2.4 and 2.8 volts with the gas cap removed. Reinstall gas cap.
3. With the scan tool, view the OBD II monitors through the On-Board System Readiness Menu.
4. Drive the vehicle at a constant speed between 56 km/hr (35 mph) and 104 km/hr (65 mph) with throttle as steady as possible. Observe the HO2S monitor on the scan tool until it completes (or refer to the Fuel Monitor or HO2S Monitor repair Verification Drive Cycle in this section).
5. Bring the vehicle to a stop and access the following PIDs with the scan tool: IAT, FLI, FTP, V, EVAPPDC, EVAPCV
6. Verify the following EVAP monitor entry condition: IAT between 10-38° (50-100°F).
7. Drive the vehicle on the highway with a constant speed over 64 km/hr (40 mph) with throttle as steady as possible. During this time, verify the following additional EVAP monitor entry conditions using the FLI and FTPV PIDs.
o FLI stable ± 5% between the limits of 15% and 85% tank fill.
o FTP V stable within ±0.1 volt.
8. Prior to running the EVAP monitor, when the EVAPPDC PID is less than 75%, the canister vent solenoid is open and the system is unsealed. To initiate the EVAP monitor, the EVAPPDC PID must increase to at least 75%. At this time, the EVAPCV PID will then display 100% (canister vent solenoid closed to seal the system and the monitor will begin to run. Continue to drive at steady throttle with light steering until the EVAPCV PID displays 0% (canister vent solenoid open, system unsealed). If this step does not occur as described, proceed to the following note, otherwise proceed to Step 9.
Note: During the drive cycle or hot ambient temperatures, fuel vapor (from the canister and/or tank) may keep the test from starting. This can be observed on the can tool when either:
1. The EVAPPDC PID never reaches 75% with stable FLI and FTP PID readings.
2. The EVAPCV PID never goes to 100% (canister vent never closes) when the EVAPPDC PID is above the 75% minimum to start the test.
9. Bring the vehicle to a stop.
10. With the scan tool, view the EVAP monitor for completion through the On-Board System Readiness Menu. Repeat Step 7 if the EVAP monitor is not complete.
Evaporative Emission Monitor Repair Verification Drive Cycle For Probe Only:
1. Check the IAT PID on the scan tool to make sure that the intake air temperature (or ambient temperature) is 4°C (40°F) or greater to initiate the drive cycle.
b. Accelerate to 64 km/h (40 mph). Maintain speed for 1 minute.
3. Rerun Quick Test . Refer to Section 4A, Diagnostic Subroutine DSR 1.
Catalyst Monitor Repair Verification Drive Cycle:
2. Start the engine and drive the vehicle for 25 minutes.
a. Drive in stop-and-go traffic for 20 minutes, include six different constant speeds between 40 and 72 km/h (25 and 45 mph).
b. Drive on expressway or highway for an additional 5 minutes.
3. Rerun Quick Test . Refer to Section 4A, Diagnostic Subroutine DSR 1 .
Fuel Monitor or HO2S Monitor Repair Verification Drive Cycle:
2. Start the engine and drive the vehicle for 7 minutes.
a. Drive in stop-and-go traffic for 6 minutes, include one idle.
b. Accelerate to 72 km/h (45 mph) [ 56 km/h (35 mph) on ******/Tracer at more than 1/2 throttle]. Maintain speed for 1 minute.
Misfire Monitor Repair Verification Drive Cycle:
1. For applications with the Fuel Level Input (FLI) circuit to the PCM (Pin 12), check the fuel gauge and the FLI PID on the scan tool (if available). The Misfire Monitor can only be tested if the fuel gauge reads above one quarter full or the FLI PID is above 15% (percentage fuel tank fill).
2. Start the engine and drive the vehicle to a location where speeds can reach 88 to 97 km/h (55 to 60 mph) and coast down to 64 km/h (40 mph) without traffic interference.
3. Accelerate at wide-open throttle to allow vehicle to shift at red-line (if equipped with a tachometer). Immediately return to normal speed limits.
4. Perform the following drive procedure three consecutive times.
a. Accelerate on highway to 97 km/h (60 mph). Maintain speed for 30 seconds.
b. Coast down with foot off the accelerator pedal from 97 km/h to 64 km/h (60 mph to 40 mph).
5. Rerun Quick Test . Refer to Section 4A, Diagnostic Subroutine, DSR 1 .
Secondary Air Monitor Repair Verification Drive Cycle:
2. Start the engine and proceed through the entire OBD II Drive Cycle until the Secondary Air Monitor shows the On-Board Readiness Menu completion status on the scan tool.
3. If the entire OBD II Drive Cycle has been performed and the Secondary Air Monitor check has not completed, rerun Quick Test . Refer to Section 4A, Diagnostic Subroutine, DSR 1 .
popsracing
EFI Calibrator
Rochester, NY
Paul, you beat me to the punch. Wait wait wait, sct value file obdII test switch set to 18 LMAO, while were at it leave the sct value file cat protection shut off; assuming you get the joke.
