Re-installing A/C
Sho Amo
SmkTyresntDrugs
Olney, Md
When I did the 3.2 swap a few years ago I ripped all my a/c stuff out. When I did that I was not thinking of having a kid. Now that I have a 6 month old, I need a/c to drive her around. I have ordered 2 parts so far...
Accumulator-
http://www.rockauto.com/catalog/moreinfo.php?pk=814852
Liquid Line-
http://info.rockauto.com/getimage/g...ttp://info.rockauto.com/FourSeasons/55722.jpg
If I am assuming correctly I still need...
Condenser
Compressor
Manifold
Discharge line
Also, I have had my evaporator uncapped since I removed everything else. Is this potentially going to cause an issue? My compressor has also been uncapped, im sure thats dead.
moobypets
mooby
quebec
compressor yes will be dead and the evaporator and the one under the dash as well
projectSHO89
SHOless In St L
Neither the compressor or the evaporator need to be replaced unless you required. The evaporator can be flushed and pressure checked for leaks. The compressor can be pulled for inspection, drain the oil, and fill back with fresh oil in the proper amount. Flush the condenser. Do NOT attempt to flush the discharge line with the muffler on it.
Put everything back together with all new O-rings, new accumulator, new liquid line, oil in all the right places. Vacuum the system and check for leak-down, then charge per specification.
Also, be careful who you take advice from....
in my experience, there is a 99% chance that the compressor will be dead. in the part of the world where the OP lives, the open compressor will have corroded enough that it will likely not do a decent job of making pressure, thus it will likely need replaced.
Sho Amo
SmkTyresntDrugs
Olney, Md
Since my car is a 91 I originally had r12. does that matter when I'm ordering line?
LJRuddy
Pop lock n drop
Poaceae fields
From what I can remember, the line is not the issue, its the fittings that differ between the R12 and R134a.
LJRuddy
Pop lock n drop
Poaceae fields
And the fitting is integrated into the line
Weird. I always thought they could be changed out without having to replace the line...
Shows how much I know about that. Guess I'll keep my mouth shut. :wave:
you can buy adapters at the auto parts store to convert the fittings from R12 (old) to R134a (new) style. not that expensive either.
32MTX
North Palm Beach
if I was going to buy new line I would just get R134 style
as thats what most people have/use these days
if u get a R12 line and want to fill it with R134, you will then need to purchase an adapter(that can leak on you) so factor that into which one costs more in the long run
PILOTOMD
SHO '93 MEMBER
TEXAS
Why not just put R12 back into it and you won't have to refit your AC system. You can purchase the R12 on ebay!
PILOTOMD
Sho Amo
SmkTyresntDrugs
Olney, Md
Found out that the lines I ordered were the r12 fittings. Just got them today :)
Anyways, now what to do. At work I can re-charge 134 for free. But I have heard that r12 is way better. Also, since the fittings are different do you have to buy r12 charging adapters?
whiteguy3
Scott MacIntire
Silver Spring, MD
It does not leak as easy as 134-A. 134-A has a tendency to leak over time.
Yes you would, but we can just change them to 134-A easier. No point in running R-12. 134-A is the standard. And it's free at the **** :)
moobypets
mooby
quebec
and r12 if i recall is no more avail anywhere
just dont forget to add the oil into the system before filling the gaz
Sho Amo
SmkTyresntDrugs
Olney, Md
You can actually still buy r12 here. I think thats what im going to go with. Ive heard people say how cold it is.
