naval-avi8or
I recently changed the plugs. I found and replaced one coil do to a small crack in the insulator boot. Shortly after doing the plugs I started getting a miss that has progressivly gotton worse. The miss is only apearent at idle up to around 1000-1200 rpm. I have pulled all the plugs and have found no signs of any wet or fouled plugs and the only carbon deposite's are on the very tip of the outer threaded area (the tip/insulator look brand new an all plugs).
The miss is very random sometimes it just last for 2-3 seconds some time it cycles for 5-6 sec quits for several seconds over and over and other times it is nearly constant (rpm drops aprox 100-200rpm). Checked codes with the Xcal and no miss codes and as bad as it is at times I don't know why that even put a code for miss fire.
I have unplugged the coils/injectors and can't seem to find any one that makes a significant difference. I also swapped the coils around to there original position and rechecked with no luck.
