cubanboi89
Is raising the idol speed on a stock motor good or bad? Will it effect gas? Will it throw a code? Why raise the Idol Speed?
You can raise the idle by turning the stop screw on the throttle body, it may throw a code.not sure if the iac will by it back down though.
Raising your IDLE speed will do absolutely nothing for performance, gas mileage...etc.
....I have the SHO Source lightened flywheel and would stall out sometimes because of it. I messed with the idle screw and got it to idle a little higher(900-1000ish). I havent stalled it out since. I havent gotten any codes either and i have been running it for a few months now. I dont imagine there being any problem with this. Or is there something i should worry about?
