skidmarks
Last Post i promise...
Again wife related - (need to park the car in the barn)
She left the sunroof open and it must have rained gallons into the car over night. Now i am not sure (but pretty sure this is rain related) what is going on. Need to know wire colors to trouble shoot...
The car thinks a door is open so the warning light is on and more importantly the interior lights stay on (making it hard to see to drive). This doesn't happen all the time, more on then off. I believe it is the driver side door because all of the door locks lock except this door when you start driving. The wiring harness (what you can see) does not appear to be damaged in any way (between the door and the firewall). I will pull the fuse if someone can tell me the location. The lights over the mirror is the annoying one. Can manually turn off the main dome lights.
The other issue, since the SHO flood, is the rear driver passenger window will not open. I guess i should have checked the rear door window switch to see if it works, but from the driver side door it doesn't open (and i believe someone tried from the back seat).
I am starting to rethink the old saying... "You cant live with them and you can't live without them"!
Again thanks for any suggestions and time...
Todd
(from another post you probably realize the car was in an accident but i really think this is rain related)
Todd
