Radiator hose: source of all evil
SHOblime
State College, PA
Well I was pretty darn sure I was doing an entire front 60k PLUS valve covers and plug well seals....I'm not! nyah nyah nyah! I used a mirror/flashlight to find the coolant leak, the engine was off so I was looking for residue or drips or something, there was some residue by the weep hole, I turned the engine on, from above it looked like the weep hole, from below it was harder to see, as I didnt' really have any equipment to get under there. Well today I jacked up the car, took off the wheel and the inner fender molding, and gave the lower radiator hose a good squeeze. It shat coolant directly onto the catalytic converter. Hmm. Take a look around the weep hole/waterpump area....NOTHING. Okay, start the engine up...look around the weep hole, waterpump...NOTHING....as the engine starts to warm up (cooling system becomes pressurized) the hose starts ******* on the cat, hmmm there's the source of smoke! it also dripped at idle, causing a puddle like the one I had found previously. The only thing unexplained is where the puddle behind (ish) the wheel, I can only guess it ran along something down there and dripped off a little back behind the shaft. Anyway, long story short the SHO gonna be back on the road after a trip to advance auto for the hose. Yay! Also I'm doing a coolant change and oil/filter while I'm at it.
TimboSHO
Intermediate
Wyoming, MI
Good Work. It's always a good idea to make SURE you know where the problem is coming from. I replaced my mom's water pump and later realized it was just a hose leak from right above. Tricky. The water pump wasn't in the best shape and had 190K on it, so it was probably good to replace it anyways....
SHOblime
State College, PA
I still plan on doing the full front/bottom/top whatever 60k service....I just don't have to do it next week, thank GOD! Time to start saving the pennies up.....
