I had the radiator replaced, I've just been too stressed lately to take care of it myself and the two year warranty sounded damn nice, afterwards the radiator fans won't turn on. I've checked all of the connections, the four pin to the fans, the CCRM connector, pretty much anything on the radiator and around, it all seems to be plugged in like it should be. I took it back to them under their warranty and they said they bypassed the CCRM, feeding the fans 12v directly and they worked fine, so the CCRM seemed to be the culprit. I replaced that and the issue still persists. I tried tracing the wires back from the main four pin fan connector to the CCRM connector and I'm getting continuity, so I'm at a loss.
Can anyone give me a rundown of things to check, where they might be and how to check them? Even if I've already checked something it'd still be nice to include it, just in case someone else comes searching for the same issue. I just think it's unlikely I had a bad CCRM that failed while the radiator was being replaced and happened to buy another bad one.
Thanks
Thanks
