rack and pinion
sballan
ma
rack and pinion is leaking on my 2013 sho,but no codes showing,how is the best away to solve the problem for now
Ta2dResqr
Central Ohio
What is leaking? It is an electric unit. If anything is leaking, it would need the unit replaced. There is no power steering fluid or gear box with fluid that is replaceable. I would be curious if something else is leaking onto the rack and pinion.
sballan
ma
My ford dealer send me this
[Primary]: DIAG : C/S: CUSTOMER STATES VEHICLE IS LEAKING OIL GETTING A BURNING SMELL WILL INTERMITTENTLY SMOKE FROM THE PASSENGER SIDE HAS CODE P0172 AND P0175 NEEDS CAR TO PASS STATE INSPECTION: C/S: CUSTOMER STATES VEHICLE IS LEAKING OIL GETTING A BURNING SMELL WILL INTERMITTENTLY SMOKE FROM THE PASSENGER SIDE HAS NEEDS CAR TO PASS STATE INSPECTION
$2,769.32
Steering Rack: INFORMATION LINE leaking on rh boot
The steering wheel is attached to the steering rack by the steering shaft. When the steering wheel is turned, the steering rack interprets the directional input and pushes or pulls the front wheels in the desired direction. The steering rack is secured to the chassis.
Majestic
Those codes sound like a bad purge valve or O2 sensors.
sballan
ma
but i have this too .$2,769.32
Majestic
Don't know what to tell you on that. My 2013 has an electric rack.
Ta2dResqr
Central Ohio
Time for another dealer. the only thing they are right about is the "leaking ON rh boot" there isn't anything replaceable to leak FROM the boot. I would see what another service center says.
sballan
ma
Tyou
