Quill sleeve removal
Mike93
Go Sabres!!!
Buffalo, NY
What's the best way to remove the quill sleev??? I can't seem to find any good info on it...
allbuti
Virginia
This has been discussed recently. Search on the title , quile sleeve removal
Despite the misspelling, there is a lot of information in that thread.
Phoenix
SHOHOLIC
QC , Canada
I think there was different versions of it , best is to replace just to be sure.
I removed mine with a "hub hammer" by placing the tool on the side of the sleeve where there is a tiny lip where you can have a grip , I got lucky and it went right out. If not , dremel or a air die-grinder with a cutting wheel.
Howdy_Doody
Chesterfield, MO
The old one is probably not worn. If the new release bearing fits with a smooth sliding fit (no slop), it's probably fine to reuse it.
TYSHO
Earth
If you must replace it, try using a torch to get it glowing orange. This breaked up anything that kept mine in place and made the removal quick.
Mike93
Go Sabres!!!
Buffalo, NY
Got it out with a combo of dremel, cold chisel, screw driver, and some wire cutters. While I probably could have kept the original on there I felt more comfortable using everything that was included in the new cleutch kit.
Thanks for the help fellas.
