quick stereo question
presidentpoo
Texas
From pictures I'm seeing there should be two new connectors back there but in my dash I only have 3 connectors total. The jbl score speaker plug, the plug with power wires and what not that was in the back of the stock radio, and one plug with 8 wires that was attached to s pillar type piece behind dash I'm assuming is the other speaker wires. This is a 1992...am I missing another connector?
presidentpoo
Texas
From pictures I'm seeing there should be two new connectors back there but in MT dash I only have 3 connectors total. The jbl score speaker plug, the plug with power wires and what not that was in the back of the stock radio, and one plug with 8 wires that was attached to s pillar type piece behind dash I'm assuming is the other speaker wires. This is a 1992...am I missing another connector?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
There is the power plug, the RCA plug which is speaker wire going to the amps in the trunk for input, and the direct speaker wire plug (attached to the drivers side inside the dash). (There is also the antennae plug and CD player plug if you have the cd player option. If no CD player, then you have a jumper plugged into the cd player port).
You say there should be 2 but you only have 3, that doesnt quite make sense. What are you trying to do, hook up an aftermarket deck?
presidentpoo
Texas
What I meant was I have 3 radio RCA and direct speaker (plus a jumper I see) should there be the one in the radio and two others not including the rcas and jumper. I am hooking up a pioneer head unit and gonna buy the standard Ford Taurus harness to use.
