Quick intake cleaning question
rendyx
Buffalo, NY
When Berryman's is mentioned for cleaning the intake manifold, are we talking about the fuel system cleaner, or is there stuff in a can which I miss during my multiple trips to Autozone? And does this trip the paint off the intake too? Thanks!
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
rendyx:
The berryman's is in an aerosol can. And your intake isn't painted, so no, it will not strip the paint off.
shojuan
sunny San Juan Bautista,
The intakes are painted. Just be careful and wipe up drips on the outside fairly quickly and you'll keep the paint stripping to a minimum.
Nickk
NE
Does anyone know what kind of paint they use on the intake i have some that wore off. Right on the lettering. Looks like crap.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Nickk:
You need to fix the cause before you try to fix the intake. Your Front motor mount is bad. If it has been that way for a while, you should probably buy all 3 mounts. After you have the motor's movement back under control, then worry about fixing the manifold.
