Quick ac question... Difference between compressors
1993MTXSHO
Its a Taurus...
Jersey
Hey all, does anyone know what the difference is between the 10p15f and fs10 compressors? Are they interchangeable? I'm looking at four seasons rebuilds and both say pag 46 but they look very different. First thought was one was for r12 but that went out the window when it says filled with pag 46.
1993MTXSHO
Its a Taurus...
Jersey
May have answered my question. One is sho one is slo. Weird because they list 93 as using a slo compressor and then 94 to 95 as sho.
How many compressors did the sho use? My understanding was 89 to 95 was the same but I want to be sure so I don't run into any issues.
1993MTXSHO
Its a Taurus...
Jersey
1993MTXSHO
Its a Taurus...
Jersey
orifice tube is Ford-speak for an expansion valve.
Ford lists separate part numbers for the 3.0 SHO v. 3.2 SHO, but I have used them interchangeably without issue. The slo part does not work.
1993MTXSHO
Its a Taurus...
Jersey
I'm worried more so with 89-93 vs 94 to 95 than I would be atx to mtx. I'm wondering if the compressor changed when they switched to r134a. But I suppose I'm curious if the atx and mtx had different units too.
AREA 91
PA SHO SHOP
Area 91
As far as I know all V6 SHO'S use the 10P15F compressor. The difference would be the oil used in the system. R12 vs R134.
1993MTXSHO
Its a Taurus...
Jersey
Ok then all I need is a way to make the aftermarket Ac line fit with headers. Probably not going to happen.
1993MTXSHO
Its a Taurus...
Jersey
What does everyone do with the liquid line then? Cut it and replace the orifice tube and reuse it? I've read that ends up leaking.
why do you want to replace the orifice?
