Quick '89 Alternator questions.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
My alternator just started making some nasty racket. It sounds like the bearings are eating themselves. Kind of like the belt squeal from ****, and only audible at an idle.
My question is simple:
What year SHOs share the same alternator as the '89?
I have one pulled from a '91, and it LOOKS like it would bolt up, but I not sure.
And if it would bolt up, is it a direct replacement? Are they rated the same?
Thanks!
revhardSHO
Seattle, WA
Thanks!
Im not 100% sure but I think all alternators from 89-91 are the same. They are all rated the same 90A IIRC. Shotimes has a good writeup on what you can use for what year. Check it out to be sure :thumb:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Thanks guys, I will see if the alt. I pulled from the '91 will fit this weekend. If that works, Ill see what can be done to save my orig. alt. :thumb:
Autobahn:
I might just do that if thigs dont work out.
Bizzy
NotSoSlowSHO said:
What year SHOs share the same alternator as the '89? I have one pulled from a '91, and it LOOKS like it would bolt up, but I not sure. And if it would bolt up, is it a direct replacement? Are they rated the same?
90 amp alternator - All 89-93 MTX
The one from the 91 will fit and bolt right up. It is a direct replacement and is rated the same providing that someone didn't change it out which is unlikely since it's a PITA to convert the MTX over to ATX style alternators.
Kenny, also keep in mind that getting an alternator rebuilt is a fairly simple thing to do. If you take it to a shop that does that you can get that done for a fraction of the cost of getting a new one.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Thanks everyone.
Except for the pulleys being slightly different sizes, it was a direct ft. I did swap pulleys though, to retain the larger more "underdrive" pulley.
I also found out why my AC want working, and why it would take a charge!
When I pulled the Alternator out, what do I see? The flippin' AC compressor plug dangling loose. it came unplugged!
So, no more alternator noises, and now I have AC :snicker:
oh yeah, life is good :D
