Questions on replacing cv joints
Blast7
Rochester, NY
Whenever I take a semi-hard right turn I get this clack-clack-clacking. After doing a search I am convinced this is the cv joint. Also, I can feel the vibrations through the footwell. How difficult is it to replace the cv joints on both sides? Also, how much money is involved here? Thanks for any help.
shojuan
sunny San Juan Bautista,
It's not that bad. A little time consuming the first time you do it. But it's a damn good skill to have. Most people will tell you to just get some rebuilt half shafts from Autozone or NAPA. They're cheap, about $60 or so and sometimes have a lifetime warranty. However don't mistake that warranty for quality, they're just betting that you won't be keeping the car for too much longer after doing a CV replacement. America has an appetite for newer cars, so they're probably right 95% of the time.
You'll need a 30mm deep socket to remove the hubnuts and you should have a torque wrench when you put it back together. Most people's torque wrenches stop at 150 ft-lbs. I'm pretty sure the spec for the front hub nuts is over 190 ft-lbs. My torque wrench goes to 11. Er.... 250 ft-lbs. If you don't have a big torque wrench already, I suggest getting one that will do more than 150 ft-lbs. Comes in handy for suspension work.
OK, about those rebuilt halfshafts. Everybody on here is going to tell you to go with rebuilts from the zone or NAPA. Much better rebuilds can be had from http://www.raxles.com
Mardi there uses only brand new outer joints (inner joints almost never fail. He'll use new if his cores are bad). He repacks with synthetic Amsoil grease and has a lifetime warranty of course. They aren't much more than NAPA or Autozone, although the shipping charges add up and there's turnaround time too. The quality is MUCH higher though. You won't have to worry about having to replace those halfshafts again unless you are the kind of guy that breaks axles on a track. Now here is where I really go against convention. I just buy new outer joints from Mardi and new boots. The parts savings isn't much more than buying rebuilt halfshafts from him and I don't get the warranty. I do save a bit on shipping though. Then I rebuild my halfshafts myself and repack with Redline CV-2 grease. It's more time consuming this way and it can be quite messy dealing with all the grease. However when it's all done I have my personal satisfaction and I know I'm not going to have to worry about the joints again.
Why are Mardi's rebuilds with new outer joints so much better than Napa, autozone, wherever? Well the cheap rebuilders regrind the joints instead of using new parts. Lol, sometimes they don't even bother to do a regrind. Either way, there's no case hardening left on the joint and it's prone to failure. Plus the synthetic Amsoil grease (or the Redline CV-2 that I use :p ) Is MUCH higher quality than OEM.
A local Toyota dealer around here used to have a rebuilder they worked with. Napa/autozone quality rebuilds. After a while they stopped offering rebuilds because of quality issues so the only option through the dealer was $300 brand new OEM halfshafts. Lol, those used Toyotas last so long that the "lifetime" warranty on crap quality rebuilds was worthless and it was causing lots of ****** off customers for the dealership.
OK, you've heard my $.02. Now the masses are going to chime in and tell you to just get the NAPA shafts. Lol, a lot of those guys are far more respected than I am so after they've just about convinced you, at least give Mardi at Raxles a call and talk to him a bit. (888) 257-8192 or (800) 257-8192
Tell him Rick from San Juan Bautista sent you. Lol, it won't save you any money but he'll get a kick out of it.
rangerj
Brunswick, Ohio
Blast7,
Ditto what SHOJAUN said. You can buy the "blue light special" or you can buy a quality product.
Do you like your SHO? As for the cost, you can call RAXELS and get the prices and S/H info.
As to the complexity of the job, it is basic nuts and bolts. You can borrow the torque wrench from Auto Zone for a deposit. I frequently see folks torquing their front axel nuts in the AZ parking lot.
The neat thing to me is that you can replace the outer CV joint and boot without pulling the axel out of the transmission. This save on a step in the process, and on the mess that invariably comes with draining the trans fluid.
If you decide to replace the outer joints and boots, and want a step by step description of the process, let us know. ranger
Blast7
Rochester, NY
Ok, I've got some interesting news. After all of this great info you guys post I don't think my cv joint is bad. Today, for the first time, when turning I felt and heard a rubbing/clanking noise coming from both sides of the engine. When I am sitting still and turn my wheel right I hear this wretched rubbing/squeaking sound coming from the right side of the front suspension. I am going to open my hood and check for movement in the engine when I turn the wheel, tomorrow, to see if my assumption is correct. Any other tests I can do to properly determine this problem?
EDIT: I just thought of one other thing. Very rarely, I will go to make a right hand turn and it is as if the steering wheel turns maybe half a turn that abruptly stops. It won't go any further. After this turn it doesn't happen again until maybe 2 weeks down the line.
<small>[ June 17, 2003, 10:39 PM: Message edited by: Blast7 ]</small>
Now THAT sounds like a rack that is about to seize!
Have you checked your wheel bearings, tie rod ends, and ball joints?
If not, do so - quickly!
Blast7
Rochester, NY
I replaced my ball joints and inner/outer tie rod ends this past weekend but the sound remains. Any suggestions? I will probably try to move this to the suspension board.
SHO--ripper
928 Euro
winsted,CT
I agree with projectSHO, it sounds like you need a new rack if the steering wheel is sticking.
KM92SHO
Burrillville R.I.
Ok someone finally said they changed the ball joints and me and my buddy are stuck in the snow trying to do this please tell me how to get it all back together it wont line up right. SHOs are a pain in my butt. Ford circled the problem.
